It is currently Wed Aug 13, 2025 9:00 am
 Post subject: Saddlematic mystery
PostPosted: Mon Nov 09, 2015 11:35 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I was going through my guitar tool drawer and came across this (picture below). All was sealed in a plastic bag including the instruction sheet. Now, I know what a saddlematic is. And none of this appears in the manual. What is this tool set?
 Post subject: Re: Saddlematic mystery
PostPosted: Mon Nov 09, 2015 11:43 pm
Methinks you've used the old bag to put some random stuff in...
PostPosted: Tue Nov 10, 2015 12:11 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Nope. It was sealed until tonight.
PostPosted: Tue Nov 10, 2015 12:13 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Looks like the bridge pin hole chamfering tool.
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Reamers/Bridge_Pin_Hole_Chamfer_Tool.html
PostPosted: Tue Nov 10, 2015 12:25 am
That looks like a plug cutter and drill stop....
PostPosted: Tue Nov 10, 2015 5:01 am
J De Rocher wrote:
Yep.
PostPosted: Tue Nov 10, 2015 5:21 am
Wrong instruction sheet
Right one
http://www.stewmac.com/How-To/Online_Resources/Bridges_and_Tailpieces/Bridge_Pin_Hole_Chamfer_Tool_Instructions.html
PostPosted: Tue Nov 10, 2015 9:01 am
Bridge hole chamfering tool, definitely
PostPosted: Tue Nov 10, 2015 11:35 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Clear sign of Tool Acquisition Syndrome
PostPosted: Tue Nov 10, 2015 3:09 pm
I have that little tool and it works very well for me.
PostPosted: Tue Nov 10, 2015 4:32 pm
First name: Jay
City: Bothell
State: Washington
Me too. I used mine the other day on a rosewood bridge. The pilot keeps the tool centered on the hole and it cuts cleanly. I use my grandpa's very old hand cranked hand drill which gives good control.
PostPosted: Tue Nov 10, 2015 4:53 pm
First name: Rusty
Now I understand why I cant locate the saddle with that tool.
Neither will the saddlematic chamfer holes!
Mike, are you buying tools and just throwing them in a drawer without even trying them out?
You do have TAS.
PostPosted: Tue Nov 10, 2015 5:02 pm
smile
had a shitty day toady, thanx for making me laugh
cheers, alex
PostPosted: Tue Nov 10, 2015 7:14 pm
First name: D
Last Name: S
Looks like what was left over when I assembled a ride-on toy last xmas.
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Nov 10, 2015 7:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
This is indeed a symptom of TAS. I don't have it as bad as I used too. Back in the day, I was a sorry case. Thanks for the ID. Maybe I will try it out for the intended purpose. I have 5 bridges waiting for chamfers.
These users thanked the author Mike OMelia for the post: Steve Jeffries (Sun Nov 15, 2015 2:01 pm)
PostPosted: Tue Nov 10, 2015 7:54 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I really like the tool.
PostPosted: Tue Nov 10, 2015 9:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Can I use it on a drill press? I don't have any directions.
Oops. I see someone posted instructions above. But, experiences are welcome
PostPosted: Wed Nov 11, 2015 4:18 am
I'm getting clean chamfers effortlessly with a small cordless drill.
Depth stop may polish the top of the bridge but does not damage it.
Rather than setting the depth stop just with the grub screw as per instructions, I fitted some 10 x 16 x 0.3 mm shim washers behind brass/plastic stop against shoulder of cutter to give consistent diameters at top of chamfer (I use 2 or 3)
Useful if you disassemble to clean the tool as it goes back to exactly the same setting and there's no chance of the grub screw slipping during use.
PostPosted: Wed Nov 11, 2015 4:47 am
yep - feed easy
PostPosted: Sat Nov 14, 2015 3:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I really like this tool. Very nice chamfers.
PostPosted: Sat Nov 14, 2015 3:28 pm
First name: Jay
City: Bothell
State: Washington
Maybe it would be worth digging through your tool drawer again to see what else turns up. [:Y:]
PostPosted: Sat Nov 14, 2015 5:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I think you are right. After these builds I'm having a shop clean out and reorg. There was a time when all I did was hang out in the classifieds here and in other sites. You wouldn't believe the stuff I bought over at sawmill creek. I don't know what that chamfer tool costs, but I recommend it. Way better than the typical chamfer tool u can get at big box.
PostPosted: Sat Nov 14, 2015 5:12 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I do have a question about that stepped drill bit for tuner installs. Will it work for Gotohs? Are there industry standards for tuner posts? I'm tired of the setup require to swap out bits and set depths
PostPosted: Sat Nov 14, 2015 7:01 pm
Last Name: Parchem
City: Seattle
State: Wa
I have a couple of those, I found you have to look at the spec for the tuner. They make a few different ones.
I found another sure fire way with normal bits. Drill a small pilot hole all the way through. On the top drill with the right size bit for the bezel the correct depth, then change to the shaft bit and drill through. The pilot hole keeps things centered.
PostPosted: Sat Nov 14, 2015 7:59 pm
First name: Jay
City: Bothell
State: Washington
I just finished installing a set of Gotoh M6 style tuners a few minutes ago. This was the first time for me making the tuner holes using a brad point bit to drill a pilot hole followed by StewMac's rear peghole reamer which leaves a step down in diameter for the tuner post (I used the drill press for both). I don't know if these tuners or the tool are the same as you have in mind, but the reamer worked as advertised.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tuner_Installation/Rear_Peghole_Reamer.html
Users browsing this forum: bcombs510, doncaparker and 23 guests
